Re: Which penetrating fluid to use on Farmall A Rear Rims
Posted by clint s on July 09, 2011 at 17:01:47 from (24.92.241.43):
In Reply to: Which penetrating fluid to use on Farmall A Rear Rims posted by Stevie J. Mote on July 09, 2011 at 13:31:47:
Machinist's Workshop Mag published this a while back. I found it very interesting
They arranged a subjective test of all the popular penetrants
with the control being the torque required to remove the nut from
a "scientifically rusted" environment.
*Penetrating oil .......... Average load*
None ........................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ............... 127 pounds
Kano Kroil .................... 106 pounds
ATF-Acetone mix...............53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone. Note the "home brew" was better
than any commercial product in this one particular test. I use it all the time and found it works very well if not better than anything I have used.
