Re: Need help installing Planter Drive Gear onto Hybrid F...
Posted by gene bender on July 09, 2011 at 18:38:46 from (207.177.56.53):
In Reply to: Re: Need help installing Planter Drive Gear onto Hybrid F... posted by gene bender on July 09, 2011 at 18:31:36:
I have the drive sprocket that bolts to the final. I got your planter mixed up with the cult. The final drive for the A takes what i have as thats where it came from do you need the sprocket also.
