Posted by Thomas Murff on July 09, 2011 at 19:10:51 from (98.87.240.109):
Ok guys i need some help. I own my granddads 574 diesel tractor and recently the clutch went out in it. I got it home and was going to fix a couple small things before i took it to the mechanic that has worked on it for 30 years. I got water in my hydraulic fluid so i drained it and while i was waiting to pick some new fluid up i was going to replace my ignition switch. After hooking up the switch i cranked it up not thinking with no hydraulic fluid i may do some damage. When i cranked up to make sure my wires were correct i heard a little grinding. I thought it was in the starter and i had some wires backwards. No sure if flywheel may have been grinding. So today after i got hy-trans back in it i cranked up and had a little smoke and after 20-30 seconds of running it locked up and cut off. WHAT HAVE I DONE?? Is there something else i could have messed up, could it be only flywheel and clutch? My mechanic knows the clutch went out but i hate to tell him i may have screwed something else up. He is going to let me have it.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
