Posted by Brownie 450 on July 10, 2011 at 05:04:48 from (66.43.241.198):
In Reply to: Pete 23 Again posted by Allan In NE on July 09, 2011 at 18:32:45:
Had the same trouble with ours. Made a bracket out of 3/16 strap about 4 inches long which bolted to one of the pump mounting studs with a double nut. This holds a lead solid washer against the original plug. You will have to cut & bend the strap to get the right fit & tension on the lead washer. Just go a little at a time to get a tight fit. If you need a washer, give a holler.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
