Re: Which penetrating fluid to use on Farmall A Rear Rims
Posted by Dean Olson on July 10, 2011 at 07:07:13 from (98.196.66.64):
In Reply to: Which penetrating fluid to use on Farmall A Rear Rims posted by Stevie J. Mote on July 09, 2011 at 13:31:47:
WD40. It sure gets bashed. There may be better products, but it's all I use. It's cheap, easy to come by, and easy to clean up. If that won't get it I heat it up.
It definitely penetrates. I just got a Super C mounted planter freed up. It had sat in the dirt under a shed for too many years. I hit it with WD40 every day for a week then started working on it. Everything came loose and it works fine.
