Posted by Owen Aaland on July 10, 2011 at 13:33:31 from (216.47.33.237):
In Reply to: A Picture of my woes posted by Allan In NE on July 10, 2011 at 11:14:58:
The groove you see is in the tappet, designed to keep it square with the cam shaft in the pump. The missing pin is a press fit in the pump housing. I do not think that there is any seal other than the fit of the pin in the housing.
Without the guide pin the tappet is going to turn slightly which can cause timing to advance a little, but more important will be the roller under the tappet will contact the cam on one end instead of full contact over the total length. If run long enough without the pin it will damage the cam,roller, and tappet.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
