Re: sterring seal
Posted by snoop-nc on July 11, 2011 at 14:09:58 from (67.213.46.118):
In Reply to: sterring seal posted by Jeff Justice on July 11, 2011 at 12:46:42:
(1)Do you ALREADY have the old seal out?? If so...you can take the old seal to NAPA/O'Reily's/any bearing & seal store and they can most likely cross ref. number on the old seal.
(2) Case/IH dealer.
(3) VERY CAREFUL measurements for seal OD...ID...and thickness. Thickness may not be quite as critical. If old seal is "thick"...you might wanna see if you can get two "thin" seals to take its place.
Good luck....Rick
