Re: 460-560 diesel starter.
Posted by Owen Aaland on July 11, 2011 at 15:41:59 from (216.47.33.237):
In Reply to: 460-560 diesel starter. posted by Bud DeLong on July 11, 2011 at 05:44:00:
The starters are not the same. The mounting holes and bolt patterns are different. The 560 starter it too big to fit in the 460.
The 460 should have starter number 1108642 or 1108657. The specs are the same for both. Test at 11.8 volts, 40 - 70 amp draw, 6800 - 9200 RPM.
Spec number 449.
The 560 uses starter number 1113053. Spec number 2412. Test at 9 volts, 50 -70 amp draw with solenoid, 3500 - 5500 RPM.
These are no load tests. They do not give any specs for lock up test.
