Re: My New Farmall C20 Two Bottom Plow (PICS)
Posted by Dean Olson on July 11, 2011 at 17:16:01 from (98.196.66.64):
In Reply to: Re: My New Farmall C20 Two Bottom Plow (PICS) posted by IH fan on July 11, 2011 at 12:25:39:
IH Fan,
There is a leveling link that goes from the fast hitch to the touch control on the left side of the tractor. It allows you
to pitch the plow left to right. This is really cool when you start plowing on level ground, set the plow accordingly,
then when you drop the wheel in the furrow you adjust the plow again. Makes for a pretty job.
The front to back adjustment is on the right side, from fast hitch to touch control, I have tried it and end up setting
it so close to the solid mount that I don't use it. That connection will not typically be on a "C" touch control arm.
I'm of the opinion you don't need it.
