Re: IH 300 Brake drum wear
Posted by Janicholson on July 11, 2011 at 18:09:43 from (67.72.98.45):
In Reply to: IH 300 Brake drum wear posted by Alexhl on July 11, 2011 at 11:37:07:
If you are discussing the housing (and not the disks)
The answer is replace it, If you want to try it you can machine down the surface that touches the dif housing to compensate for the wear. The total stack thickness should have .030" to .050" free space when the adjustment is totally loose. Jim
