Re: What do I have here
Posted by mkirsch on July 12, 2011 at 05:09:34 from (64.80.110.75):
In Reply to: What do I have here posted by Bill Bowen on July 11, 2011 at 15:00:49:
Now Randy, you presumably grew up in a farming environment and you know that farmers often do what is necessary to get the equipment up and running. They don't always fix it "right."
It probably wasn't a matter of not being able to find the correct condenser, but having THIS condenser on hand, and needing the tractor to run NOW.
The only reason you'd need noise suppression is for a radio. Is there any evidence of the tractor ever having had a radio installed?
