Re: H-4 magneto problems
Posted by El Toro on July 12, 2011 at 06:39:52 from (108.15.86.54):
In Reply to: H-4 magneto problems posted by ryanwheelock on July 12, 2011 at 05:05:43:
Rub those new points with some 320 wet or dry then see if it will start. Did you remove gears inside the mag? If you did they may be out of time.
