Posted by The tractor vet on July 12, 2011 at 07:36:55 from (99.167.210.147):
In Reply to: 706 G ??? posted by MattSillinois on July 12, 2011 at 05:52:44:
What do you mean it will not pull anything? When they are running correctly they run great, IF they are tuned correctly run the co correct oil and ya run the correct fuel. Myself i have run 706 gassers for the better part of 35 years and have gotten along fine with them. My two closest friends run them and they get along just fine with them . As for engine RPM i usually set them for 2500-2600 high idle . Now as for tune up spec.'s we need to know IF it is a C263 or a C291 . And if it has or has not been up graded from a C263 to a 291. I have found that i have had the best luck running A/C C 86 plugs or Autolites when i can find them. Keeping the timing set to the engine size is vary important on them as this is where ya really need to know just what engine you have as the timing does not set the same . GAS, is the next thing YOU HAVE TO RUN 93 octane. If you do not believe me on this you had best get and Org. owners manual and READ about minimum octane fuel requirements for this tractor. Now If your tractor is lossen power coughen spitten and sputteren when coming under a load it may be to late and engine damage may have already been done because of tryen to run it working under load on 87 octane gas . 87 octane burns way to hot and it will super heat the pistons and cause them to expand and guild to the sleeves , also incorrect ing. timing will not help. Next the type of engine oil is a nother thing that they are vary fussy about . here ya have to run a Low Ash oil or deposits will build on the exhaust valves and torch a cute little Vee in them so fast it will make your head spin. How do i know this , because i have been down this road before . In other word a I H gasser has to be FEMALE and as long as ya do what she wants she will be good to ya but try and short cut yous going to pay.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
