Re: H-4 magneto problems
Posted by monkeyrun on July 12, 2011 at 08:55:48 from (173.202.26.185):
In Reply to: H-4 magneto problems posted by ryanwheelock on July 12, 2011 at 05:05:43:
There is fairly tight fit between the metal case and the terminals for the wire going to the points. If the case grounds out that wire, no spark. On all mine there is two ply of elec tape over that screw and terminal before I put the case back together just to be sure the hot wire ain't grounded to the case. Or else double check that those terminals are pushed inward as far as they will go to clear the case.
