Posted by Welding man on July 12, 2011 at 14:27:19 from (76.9.225.108):
In Reply to: sleeve removal ? posted by buckyfarmer on July 12, 2011 at 13:26:42:
Why does anyone do an inframe overhaul?Half azz at best.You can't get things cleaned up properly.You can't change the rear main seal, check the timing gears for wear or check the clutch. Half azz jobs always bite me in the same place.I say fix it right or scrap it.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
