Re: Cub Lo-Boy 185 coil question
Posted by Janicholson on July 12, 2011 at 20:28:50 from (67.72.98.45):
In Reply to: Cub Lo-Boy 185 coil question posted by onehardcase on July 12, 2011 at 15:35:19:
With a charged battery. Turn on the key and measure the voltage at the distributor terminal. If voltage, turn the engine till the points close. (No voltage there now)
Then measure the voltage at the coil terminal connected to the ignition. If it is 12+ volts you need a 12 volt coil no resistor needed.
If it is between 8 and 6 volts you need a coil made for use with a resistor. Some of the IH tractors had a resistor built into the wire going to the coil, it is actually the wire, and not obvious. Jim
