Posted by El Toro on July 13, 2011 at 06:28:17 from (108.15.86.54):
In Reply to: Re: cub farmall posted by Whitley on July 12, 2011 at 09:56:03:
Make sure you have the plug wires installed on the cap in this order:
2-1 4-3 As the rotor rotates CW
If this is ok bring No1 piston to TDC on the compression stroke as I described earlier. Hal PS: Hold your hand over the throat of the carb while a helper makes an attempt to start the engine. Should have good suction on your hand. Low suction means you have low intake manifold vacuum. Do a compression check and compare the readings.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
