Re: Farmall 300 Carburetor - Replacement
Posted by rustyfarmall on July 13, 2011 at 07:06:35 from (216.248.71.224):
In Reply to: Farmall 300 Carburetor - Replacement posted by Kevin Rapes on July 13, 2011 at 05:59:29:
A carburetor that has been completely disassembled, thoroughly cleaned, and reassembled with all new wear parts and all adjustments set to factory specifications will be every bit as good as a brand new carburetor.
A few gaskets and paint job DOES NOT qualify as a rebuilt carburetor, so be very careful of who does the work.
I have rebuilt and sold countless Farmall H and M carburetors and I've never had any complaints. I would fix you up with a carb for your 300 but I do not have one at this time.
I will also add that NO carburetor kit will improve anything if all you did was take the carb apart and put it back together using a few new parts.
