Re: Farmall WD9 rear Tire Size
Posted by rustred on July 13, 2011 at 08:42:04 from (74.200.18.156):
In Reply to: Farmall WD9 rear Tire Size posted by luv2wrench on July 13, 2011 at 06:34:01:
the correct tire for the WD9 is 16.9x34 .
the rim is installed with clamps and bolts.the Super WD9 has 18.4x34 tires mounted on a wider rim , rim is installed with 5/8 bolts through hub and rim.
