Re: 460 farmall hyd. problem
Posted by pete 23 on July 13, 2011 at 18:30:52 from (74.32.234.149):
In Reply to: Re: 460 farmall hyd. problem posted by 11Zach on July 13, 2011 at 11:16:21:
Ok, then the valve that is operating the hitch has a double single action adjustment on it . Check that out first, really simple and many, many are the culprit. It has a roll pin that goes through the adjustable stem or rod on valve and it has a marking of s and d with a stop so it can only go so far. They get bent or broke and then will stay on demand when turned past intended point.
