Re: Farmall 300 Carburetor - Replacement
Posted by Kevin Rapes on July 13, 2011 at 19:37:06 from (71.10.136.145):
In Reply to: Re: Farmall 300 Carburetor - Replacement posted by sflem849 on July 13, 2011 at 08:42:16:
At first I thought it would be the same as the H (since the majority
of the parts for the engine are). However, when I was at a tractor
show this year I made a point to look. From what I found it"s a
totally different design (on how the throttle, choke, etc hook up).
Before that I had figured it would be pretty easy to swap one out for
an H"s, but then I found otherwise. I"m not sure about the Super H
though.
