Re: Super C-200 Auxiliary valves plumbed opposite
Posted by IH fan on July 13, 2011 at 22:27:47 from (99.38.204.64):
In Reply to: Super C-200 Auxiliary valves plumbed opposite posted by Jay Rider on July 13, 2011 at 21:02:49:
Dean Olson said: (quoted from post at 23:02:49 07/13/11) I have a SC & 200 with fast-hitch. When I push FORWARD on the auxiliary control valve lever on the SC the fast hitch raises. When I push FORWARD on the 200 lever the fast hitch lowers.
Which one is correct?
Our Super C (bought new) was Forward raised- Back lowered... This made the rear of the cultivator work the same as the front with the Touch control... switch the hoses to the 200 cylinder.
This post was edited by IH fan at 22:28:14 07/13/11.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
