Posted by D Slater on July 14, 2011 at 11:07:51 from (184.15.41.100):
In Reply to: freeze plug on M posted by e-manhunt on July 14, 2011 at 09:23:17:
Freeze plugs are what they are called a lot, but not the best name. Could be wrong but think the holes have more to do with the casting process than anything. Openings to install or remove casting sand. Most blocks will crack when froze reguardless of the plugs. Location on M blocks is in the ends, front and rear engine parts or plates are removed to access plugs. There's a engine serial number break when the plugs were no longer used. Sometime in september 1944 for M engines in M tractor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
