Re: Ih-1000 loader return hose pulsating
Posted by oldiron29 on July 14, 2011 at 17:30:04 from (69.112.87.249):
In Reply to: Ih-1000 loader return hose pulsating posted by chad from michigan on July 14, 2011 at 17:04:17:
Chad, To get the air out run the bucket arm full up and than down a fue times. Most time if the touch control is pulsating that meens you have a bad O ring some where. If your fluid was low did you check the crank case oil? If oil in crank case is high your pump has a bad O ring.
oldiron29
