Re: Re: Re: 706 Tran Fluid
Posted by SDman on August 10, 2000 at 21:29:00 from (63.83.208.134):
In Reply to: Re: Re: 706 Tran Fluid posted by Z-bar on August 09, 2000 at 03:32:21:
Z-Bar, that is correct if the rear end has never been worked on. Originally, the 06s & the earlier 56s had a soft plug beside the inner bull-gear bearing that sealed the axle housing separate from the rear-end housing. You filled the axle housing to the level of the check/fill plug on the side of the axle housing separately from the trans. level dipstick. Now, if you ever worked on the rearend so that you had access to the plugs, you were supposed to knock those plugs out so that the axle housings & transmission case were one big, common reservoir that was just filled at the dipstick. More than likely, your rear end on your 706 has never been worked on in that area. This is the way the 66s & 86 Series were set up from the factory.
Post A Followup
: Re: Re: Re: Re: 706 Tran Fluid
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
