Re: Super A Clutch
Posted by CNKS on July 14, 2011 at 19:27:08 from (216.144.104.128):
In Reply to: Super A Clutch posted by Bryn on July 14, 2011 at 19:13:43:
Free play in the clutch pedal should be 1-1.25 inches. With that clearance it will release where it is supposed to. I don't pay too much attention to the release point, as long as it doesn't grind when shifting gears. You might try tightening the loose finger, but working through that small hole is difficult. I have recently split a Super A, and C and just now got my C back together, both for engine overhauls. Not particularly difficult, just time consuming. You probably need to closely examine the clutch, along with the release bearing and pilot bushing, anyway.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
