Actually the M&W pump can be used with either rotation. The difference in the pump structure is how the front seal drain port is routed. On the OEM pumps there is only one seal drain port so that has to be on the suction side. M&W built there pumps with a drain port to both the pressure and suction side of the pump. Each side has a check valve so in use the seal will drain only to the suction side.
If they will actually interchange I do not know. The one on My W9 certainly looks like it may fit an M and an MD but I'm not going to take it apart to find out for sure. At the very least I think you would need a different gear between the two different series tractors.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
