400 diesel primary pump coupling
Posted by Workman on July 15, 2011 at 00:45:13 from (66.59.120.251):
I pulled my primary pump out this week to replace the seal. What I found is the shaft on the pump and the coupling are both worn and sloppy. Also the roll pin that holds the coupling to the primary pump shaft was missing. Does anyone know if you can get a replacement coupling? I thought about installing a new roll pin and tack welding the coupling to the shaft as a last resort. Any input would be greatly appreciated. Thanks
