Re: Farmall M water gauge disaster
Posted by AES on July 15, 2011 at 03:39:06 from (75.170.139.63):
In Reply to: Farmall M water gauge disaster posted by TC2 on July 14, 2011 at 21:53:33:
I think I was incorrect when I said it was made of brass its a yellowish metal so must be a mixture of metals (copper?).
The wrench size to fit the water gauge block insert was 7/8". Threads are nearly 3/4 but am not 100% sure. The gauge sensor insert (the one attached to the end of the wire) looks like 1/2" as you mentioned.
It is the larger block insert that was twisted off. As mentioned, I'm not sure a helicoil can be found that large.
I have a new gauge (with temp. sensor insert and block insert).
The tractor is a 1952 Farmall M
Allen
