Re: H brake questions; please help me fix Grandpa's tractor
Posted by mkirsch on July 15, 2011 at 04:42:34 from (67.253.161.186):
In Reply to: H brake questions; please help me fix Grandpa's tractor posted by Shorthorns on July 14, 2011 at 23:22:50:
They made over 350,000 Farmall H tractors, usually several in any given salvage yard of any size. Finding parts should not be a major issue. I'm surprised.
If Zach's doesn't work out for you on the pans, try Wengers of Myerstown, or JP tractor salvage, or steel wheel ranch.
The seal does have an outer metal part. If you didn't get that out, it's still in there. Original seals are about double the thickness of what you'll get at the dealer today. One modern seal is adequate and will be easier to remove down the road.
On the brake bands, look for a shop that rebuilds clutches to get your originals relined. Have them use clutch liner instead of brake liner.
All the new bands are made by the same Chinese factory, so they will all have the poor fit issue. HOWEVER, it's been a couple of years since I've read a complaint about the brake band fit. They used to pop up all the time. Take a look at the messages you're finding and see how old they are.
