Re: Mccormick Deering 10-20 carb and mag help needed
Posted by fordpower30 on July 15, 2011 at 04:44:09 from (74.220.161.21):
In Reply to: Re: Mccormick Deering 10-20 carb and mag help needed posted by oldiron29 on July 15, 2011 at 03:05:26:
If I set the mag back a hole, it won't fire until after TDC. Do I need to change the timing in the mag so it is at full advance when the coil trips at TDC?
Also, 2-3 turns out on the fuel jet has the screw almost all the way past the finger that holds the teeth on the outside of the screw. does that sound right?
Thanks, Tyler
