That coupler is threaded on, so you need to unscrew it. Might need to drop the belly pump to gain enough room to work.
Put the transmission in reverse. Set the brakes (both of them). Place wooden blocks such as 4x4s in front of and behind at least one rear tire.
Find a length of 1/2" x 1/2" key stock, place the keystock into the slot on that coupler. Put a large wrench on the keystock, say a few choice words and do some grunting and that coupler should come loose. It is right handed threads. After that, it is just a matter of digging out the old seal and inserting the new one.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
