Re: fuel
Posted by Janicholson on July 15, 2011 at 09:53:48 from (199.17.6.66):
In Reply to: fuel posted by mike ballou on July 15, 2011 at 08:00:15:
Two suggestions:
Shut off the fuel at the tank at each shutoff, no matter how short.
Check the battery cables to assess their conductivity (check for heat on terminals and along the wires and grounds. Low voltage at the coil when hot can make it not start. Pulling the coil wire when it is not starting, and moving it to about 1/4" from the block, then cranking it to look at the spark can help assess the spark. It should be blue and crisp. If yellow and stringy, or won't jump that gap. it could be either a weak coil. or battery voltage as mentioned above. Another quick check is to pull it with another tractor if it starts immediately, it is a spark issue. Jim
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
