Re: W 6 Rear Axle issues
Posted by glennster on July 15, 2011 at 10:47:21 from (75.57.117.120):
In Reply to: W 6 Rear Axle issues posted by jaybird2 on July 15, 2011 at 09:37:11:
there is a serial number break on the seals.
felt washer 51982d ser 501-2926
felt washer 60630d ser 2927 up
rear axle oil seal 51983d ser 501-2926
rear axle oil seal 60624d ser 2927 up
rear axle carrier cap gasket 56320d
rear axle sealing ring 60631d
i have the i-h tc-33d parts catalog for the w-6 series if you need any other info.
