Re: Farmall M water gauge disaster
Posted by AES on July 15, 2011 at 11:28:47 from (12.68.215.214):
In Reply to: Farmall M water gauge disaster posted by Tom Fleming on July 14, 2011 at 21:53:33:
d beatty,
Thanks for the tip. I think I purchased the extractor set at NAPA. I'll have to check. It was such a huge inconvenience to find a welder to travel to the farm to remove the brocken stud (with extractor in place) that I've been a bit paranoid about ever using one again. The welder in my home town (Greenfield, IA) is always too busy for small jobs (even though I'm a paying customer). I found a retired welder in another town very friendly, who was happy to do the job for $30.
Can you recommend a specific brand of extractor that you have used with success?
Also, since you have much more experience than I what penetrating oil do you recommend? I've always used WD40.
Thanks again for any help. I'd ultimately like to remove it without drilling a helicoil hole.
Allen
