Re: Farmall M water gauge disaster
Posted by Fixerupper on July 15, 2011 at 16:34:30 from (207.199.205.239):
In Reply to: Farmall M water gauge disaster posted by AES on July 14, 2011 at 21:53:33:
Or if you don't have a die grinder or Dremel grind down a hacksaw blade so it'll fit in the hole and start sawing away with the teeth pointed so it cuts when you pull it out toward you. There are handles made for this too. It's tedius for sure but it works in a pinch. Cut two slots opposite each other and then cave the bushing in with a small chisel or punch. Doesn't hurt to kick back and have a beer when your arm starts hurting and you start getting frustrated. Jim
