Posted by Charles E. McNelly on July 15, 2011 at 19:04:13 from (67.198.56.22):
In Reply to: W 6 Rear Axle issues posted by jaybird2 on July 15, 2011 at 09:37:11:
jaybird, I went through the same issue last summer on my W6. What I did was pull the pto from the tractor and working through the hole I took the bolt out of the bull gear and slid the entire axle assembly out. Then with a good size rose bud, heated up the steel sleeve. Slid right off. Most likely, if it's leaking the outer bearings need to be replaced as well. I had to order the felt seal from IH but everything else I ordered from a local bearing supplier. Alot cheaper that way. Charles
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
