Posted by 36F30 on July 16, 2011 at 06:35:51 from (71.214.211.46):
In Reply to: Overhauled F-20 posted by Tom Fleming on July 16, 2011 at 02:11:19:
Tom Fleming said: (quoted from post at 02:11:19 07/16/11) ok, slow down a minute. I agree with the posts so far, but 15-20 seconds is NOT enough time for the oil filter canister to fill up. These are splash lubricated on the crank. If your oil is at the correct level, run it for 2-3 mins, then look at your oil pressure. Gordon is one of the best for parts, so I would think he sent you the correct guage, IF you gave him the correct information.
Before you go tearing into things, start it up and let it run for a few mins before checking the oil pressure. Did you oil the valves before starting it?
I disagree... if you don't have oil pressure in 20 seconds you have a serious problem and you better shut it down, if you have to wait 2-3 min for oil pressure you are going to be visited by engine parts exiting through new holes. The pump is submerged in oil and should pump instantly and build pressure in a few seconds.
This post was edited by 36F30 at 06:36:54 07/16/11.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
