Re: convert 140 fertilizer drive to electric
Posted by janicholson on July 17, 2011 at 05:51:22 from (199.17.6.10):
In Reply to: convert 140 fertilizer drive to electric posted by jacks on July 16, 2011 at 20:07:47:
My best suggestion is to use a form of wheel drive. The setting of the speed and powering of the system is a task for a servo engineer. The 140 electrical system is not very clean in terms of Interference and transients, it would need to be conditioned. The shafts turn in proportion to ground speed and application rate, so a single speed is not usable. a servo motor, controlls, and drive amplifier is needed, as well as a "motor" cxapable of driving the shaft.
A wheel driven by the ground would do well in making the application work as needed. As the wheel was lifted the fertilizer would stop. As speed changed the rate would remain proportioned.
By best input. Jim
