Posted by 36F30 on July 17, 2011 at 10:14:54 from (71.214.211.46):
In Reply to: Hand cranking F-20 posted by Evan Mellott on July 17, 2011 at 09:54:55:
Evan, the plug on the bottom of the carb is actually a type of vent that allows excess gas to drip out. I find some have been replaced by pipe plugs, but that plug is the only way for excess gas to drip out and not flood the engine. It should have a piece of felt in the plug.
Each one starts a little different you just have to figure yours out, generally mine start like this. Set mag to start position, Set starter impulse( if manual set), turn on fuel at tank, set choke to full and upstroke crank one time, turn off choke,(a few drips of gas usually drip out of vent plug) recheck impulse, upstroke crank until it starts usually in one or two pulls. I never use the primer cups but some do, just make sure they are closed or it will never start as they won't let vacuum build in the carb if they are open.
This post was edited by 36F30 at 10:19:37 07/17/11.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
