Re: Strange noise
Posted by Roger46 on July 17, 2011 at 16:34:28 from (72.101.65.31):
In Reply to: Strange noise posted by BEL@IN on July 17, 2011 at 03:05:36:
Make sure you haven't sucked up a screw from the carburator choke or throttle plate. We had that happen on an H and it was a knocking sound intermittently, depending on if the screw stuck to the piston on not. We removed the screw through the spark plug hole with a piece of wire and some grease on the end. Roger
