Posted by CNKS on July 17, 2011 at 18:29:30 from (216.144.104.128):
In Reply to: pepper, again posted by blunted on July 17, 2011 at 17:49:46:
The newest spec is 85 ft lbs. Don't go any higher, I have 3 of those engines and they don't leak. You said earlier you have an A and the gasket is for a 123? Tractors with a factory 123--not an overbore kit like you have -- have water pumps, that is why your gasket says 123. Regardless of your displacement, if your engine does not have a water pump, you need a C113 gasket. The water holes in it are larger, the C123 gasket has smaller holes. That may or may not be your problem, but it may be, particularly if your radiator is pressurized -- but if it is, it is not original, many have been changed. The earlier comments about being sure the head and block are flat still apply.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
