Re: Are these hoses hooked up correctly?
Posted by pete 23 on July 17, 2011 at 18:34:03 from (74.32.234.149):
In Reply to: Are these hoses hooked up correctly? posted by matt1983 on July 17, 2011 at 17:55:56:
That tractor has a double action check valve and hoses are hooked correctly. If the hoses were reversed with a teledepth it would not raise and lower. The first 460's had single action check valve and then the lower hose would be hooked in to the left lower port which is just a block brazed to end of hyd pipes. If you don't have teledepth, and do have double check valve you could hook hoses either way and it would work but the hitch is supposed to raise when you pull the lever back, opposite of the 400 tractors.
