Re: 806 steering
Posted by pete 23 on July 17, 2011 at 18:38:41 from (74.32.234.149):
In Reply to: 806 steering posted by truckerlary on July 17, 2011 at 18:32:57:
Steering control valve on an 806 is mounted on top of TA housing directly above MCV. It may not be centering properly. Pretty easy to take apart and it has to move very freely. There is also a light spring available to overcome steering wheel slipage and they steer much easier with that. If your front axle is out of wack it will pull to one side also. If that is ok, I would think it has a leak in front bolster as even in neutral some pressure is applied to both sides of cyl in bolster.
