Re: pepper, again
Posted by Owen Aaland on July 17, 2011 at 20:21:16 from (216.47.33.237):
In Reply to: pepper, again posted by blunted on July 17, 2011 at 17:49:46:
Your earlier post indicated that you have had the problem since an engine rebuild. I am going to assume that means you replaced the sleeves. If you did, what are your sleeve to deck height measurements? Sleeve height above should generally be .000 to .005 inches above the deck. More important is no more than about .002 between any two adjacent sleeves. If those specifications are off you likely never will get a head gasket to seal.
