Good advice about getting it running first. If at all possible, try to "un-stick" the motor, then work toward getting it to fire (may be rather hard to do, since I don't see a carb attached to the intake).
The process of bringing it back to a running state before restoration does several very important things. First, you will familiarize yourself with the tractor, and its basic operation and construction. Secondly, you will be able to systematically evaluate the main systems (fuel, electrical, lubrication, etc.) for defects and flaws. Lastly, after having the tractor running, at least once, and regardless of how poorly, you will have the psychological impetus/drive to help see you through those difficult times when the tractor is in a thousand pieces, and you are wondering why you ever got yourself into this mess.
The last part of the above, I know about very well.
I left my country home about 12 years ago for the city to begin a new life, and finish raising my family (not enough money "back home"). Kept the old home place, but left my old Farmall H parked in front of the pole building in the weather.
Didn't go back till two years ago. Thankfully, no one had broken into the pole building, or otherwise molested much. Tractor was where I had left it, complete with flat tires, a thick covering of green moss, and LOTS of rust, brush, leaves, sticks, etc. Oh, and there was a 7" sycamore growing up between the drawbar and the axle housing.
I realized that if I did not get it running again, I probably never would. After much effort, and actually little expense (oil, filter, plug wires, cap, rotor, etc.), it is once again in a running state. Belches blue-black smoke when fired up, barely maintains oil pressure, brakes shudder like they have Parkinson's, and runs rougher than the Rocky Road to Dublin, but it does indeed run.
The tractor is, and has been since I got it running, parked INSIDE the building, sports a new battery, steering wheel, rebuilt carb, and various other parts, along with a growing savings account that will permit me to completely overhaul it this winter. In a pinch, and until I begin tearing it down, I can fire it up at will, and use it if necessary.
Moral: Try to get your tractor running first. The rest will seem so much easier.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
