Re: Farmall A PTO delete cover
Posted by gene bender on July 18, 2011 at 02:18:09 from (207.177.56.53):
In Reply to: Farmall A PTO delete cover posted by Farmall plowboy on July 17, 2011 at 15:48:23:
Do you want the flat one that covers the whole tranny. I have them if thats what you want.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
