Re: Are these hoses hooked up correctly?
Posted by TedinNE on July 18, 2011 at 06:21:57 from (74.85.105.134):
In Reply to: Are these hoses hooked up correctly? posted by matt1983 on July 17, 2011 at 17:55:56:
Thank you for the picture matt1983. Shows just how they should be.Knew what I wanted to say on your previous post just got my ports mixed up. Must be getting old.
Back to your problem, in the early 60's worked of a 560 with the same probled. Went through the teledepth valve regulator and follow up linkage. Had it so fine tuned you could just barley move the teledepth lever and the hitch would respond & go off pressure. Just go out and put it to work & would go on high pressure & heat up the system. Found the check block had enough wear in the piston bore the oring could not seal. Replaced the check block & no more problem.
