Posted by D Slater on July 18, 2011 at 14:05:59 from (184.15.41.100):
In Reply to: 400 diesel posted by Workman on July 18, 2011 at 11:07:51:
First filter the fuel gets to should bleed gravity from tank unless there's a problem in lines or water trap. Final should have primary pump pressure if pump is getting fuel flow. Yes some will run without the primary pump working. If you have fuel flow and no pressure on the pump gauge, check the primary pump again. Did you check the pump out for a problem that may be the cause of coupling to fail? Sometimes the primary pumps have gear damage or gear clearance problems when the coupling fails.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
