Re: 1086 IH tractor
Posted by Redfan on August 11, 2000 at 14:47:15 from (203.87.53.9):
In Reply to: 1086 IH tractor posted by Rick on August 11, 2000 at 13:54:34:
I've no experience with the forage harvester Rick, so just a few comments on the 1086. 414 motor will be like all IH 400 series motors, excellent. Trans. will have one weak link, the TA. If it has been replaced with the new mechanical diode type you'll have no problems, if not, it will pay to put one in when the TA goes. Other bearing that might give trouble is the diff. pinion bearing, if it goes , re-race the whole trans. while you've got it down. Good cab, good A/C. Regards, Redfan.
Post A Followup
: Re: Re: 1086 IH tractor
